New from Wa
New from Wa
Digging out my grandparents 68 F250 from the neighbors yard where its been "resting" for the past few years. 390/c6 camper special, over 500k miles....
- kf7mjf
Re: New from Wa
Where in wa are you? Good luck with the project, also pics man, pics!
1967 F-100 Ranger
- Kurt Combs
Re: New from Wa
Stomp down those blackberries and hook a chain to it and pull it out. Then to make you feel better about your project immediately get out your power washer and clean as much of it as you can, including the outside of the camper. You will be amazed how good it looks!
Kurt
1972 F-250
1972 F-250
Re: New from Wa
Had to put the Chevy in 4 low to drag her out. Hooked the jumper cables to it after cleaning the epic rat nest off the intake manifold. Doesn't seem to be getting fuel. Starts if you pour it down the carb, but can't pull it from either tank.
- kf7mjf
Re: New from Wa
Wow! There is a truck under there. Can't wait to see it when you have it out.
1967 F-100 Ranger
- fireguywtc
Re: New from Wa
Bill
2024 F350 CCSB, darkened bronze
- basketcase0302
Re: New from Wa
"Aint' no hill for a climber is what I've always said.
Can't wait to see the end result down the road aways.
- 1970FordTK
Re: New from Wa
Welcome from North Carolina.
- kf7mjf
- Mancar1
Re: New from Wa
Nice
Welcome aboard from Northern Ca
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: New from Wa
Update.
Camper is gone, truck is now at my house. Thinking modern power, lowered, to use as a tow rig for my offshore boat....
What are people swapping in?
Re: New from Wa
