Mounting a 2WD cab on a 4WD Frame
71PA_Highboy
Post by 71PA_Highboy »
OK,
So there are extra holes to drill, no worries... but I am using a 68 Cab, and the tank mounts differentlt than the 71.... so when mounting the 68 tank in the retainer plates, to which set of bolt holes do the retainer plates mount? Does the 68 4x4 have different lower tank mounting brackets than a 2WD?
Hope the question is clear... the solution isn't.... ;)
TIA!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
basketcase0302
Re: Mounting a 2WD cab on a 4WD Frame
Post by basketcase0302 »
I believe our newer tanks don't use the retainer plate, (instead-we have the carriage bolts that run through the cab itself).
Not real sure if that answers your question or not-but this might:
Because of the 3-bolt design of the early tanks vs. the 5-bolt design of the later tanks, they are not interchangeable without drilling the tank lip. The later tank also is bolted in at the bottom flange, whereas the early tank simply sits in a pair of grooved plates secured by the rear cab mounting bolts.
Taken from the tutorial here, (about half way down on Page-1):
http://www.fordification.com/tech/67-72ID_01.htm
Also be wary the fuel pick-up lines are different. :wink:
71PA_Highboy
Yep read it.... but it doesn't state how the retainers are mounted since I will be using a 68 tank in a 68 2WD cab drilled for a 4WD...
Got Ford?
1 Lincoln Mark VIII
hazelnut
Post by hazelnut »
The 2wd cab uses the inside holes for cab mounts, a 4wd uses the outside holes for cab mounts-- they need to be drilled useing a 2wd cab. You'll need 4x4 tank mounts to work, the 2wd tank mount's don't come out far enuff to work on a 4x4 mounting location.
zakt
Post by zakt »
2wd, F350 also have outside mounts like the 4x4...
1972 Ford F350 crewcab
harrysnyder
Post by harrysnyder »
What holes need to be drilled? I'm putting a 71 2wd cab on a 68 4x4 frame. I don't understand what cab mount and gas tank issues will I have?
I build driveshafts.
www.carolinadriveline.com
71 F100, 302, C4, 8.8, crown vic swap
68 F250, 360, NP435, Dana 24, Dana 60's f&r
71PA_Highboy
You won't have any tank problems.... but you will need to use a 71 tank and fuel line. If you have a 68 tank and want to swap (I have a 71 and need a 68), let me know!
You will need to drill the cab mounting holes... I lined up the cab and drilled from the bottom up (wear eye protection!) so that there would be no question if the holes were in the right place... ;)
You will need to fill the holes for the old cab mounts....
The problem only happens going backwards... ;(
Got Ford?
1 Lincoln Mark VIII
harrysnyder
I have the 68 tank that came out of the truck, just PM me...
