rear axle code
black70cs
rear axle code
Post by black70cs »
I was decoding my new 70' camper spec. and the axle code it says 38. I don't see 38 under 70' in the vin sect. But there is under 69' Dana 60 3.73. Is this just a mistake or what? I know it has a dana 60 but trying to figure what gears it has. Thanks.
Charlie
72hiboy4x4
Post by 72hiboy4x4 »
if all else fails, crawl under the truck and look for the tag hanging off one of the bolts holding the cover on.
maybe the factory only had 69 axles hen they built your truck. or it was an early 70. or maybe it was changed at one time.
HOWDY69
Post by HOWDY69 »
The Chilton manual says 38 is a 3.73 starting in 75. I don’t know why I am telling you this since I have very little faith in their tables. :hmm:
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
black70cs
re: rear axle code
Post by black70cs »
Thanks, I'm going to climb under there this weekend and look for a tag. I'm guessing it's a 3.73. When I drove it home it did'nt really scream for another gear coming down the road unlike my 66' with a 4.10. I just wonder why the tag has a code they did'nt use in 70'. I know it's the original door with factory rivets.
Charlie
4x4x4crewcab
re: rear axle code
Post by 4x4x4crewcab »
My Ford Master Parts Catalog (May 71) shows code 38 for 70/ up trucks as being------Single speed,3.73 (5.2 M),Dana 60
Hope this helps.
Mark
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
re: rear axle code
The '70 VIN page has been updated to show this. Thanks Mark!
black70cs
Post by black70cs »
Thanks again, nice to have people who actually like to help out.
