Hi, I need to buy D44 King Pin kit for my F100 1967 D44 4x4.
Nothing in Broncograveyard, Broncohilc, etc
Regards
Raul
F100 67 4WD King Pin Kit
Re: F100 67 4WD King Pin Kit
I'd try a Carquest or a NAPA store.
- 70_F100
D44 doesn't have kingpins.
That MAY be your problem in searching for what you're looking for.
That's not an oil leak That's SWEAT from all that HORSEPOWER!!
- averagef250
Yes they do. Early 70's and older 1/2 ton were open knuckle KINGPIN, not balljoint.70_F100 wrote:D44 doesn't have kingpins.
The kingpins or caps are usually fine, you probably just need the trunnion bearings and races to replace ones that are toast.
- 70_F100
Sorry to disagree, but a kingpin goes from the top of the spindle to the bottom of the spindle, just a single steel rod.averagef250 wrote:Yes they do. Early 70's and older 1/2 ton were open knuckle KINGPIN, not balljoint.70_F100 wrote:D44 doesn't have kingpins.
On a 4x4, that's not possible.
Edit: I guess Dana called the top and bottom pins "kingpins".
Still, not a true "kingpin" by definition.
I actually have a 1969 f100 4x4 with a high pinion Dana 44, coils, and the open kingpin style knuckles. I want to do an axle swap so I've got discs in the front. I wish I could just swap knuckles but that's apparently not possible as they switched to ball joints. My question is, what years are compatible? Is it the 1976-1979 f100s or broncos that have the front axle I need? any help would be much appreciated.
