has anyone had any experience in doing so???
i lowered it so much, im adding 4 degree shims to change the pinion angle so its not so drastic, and so i wont blow any u-joints.
would shortening, or converting to a one piece driveshaft benificial?
Thanks!
-brandon
shortening driveshaft
- greasemonkey060
'64 F100 SWB 8" notch, & triangulated four link w/ 2600 Firestone bags out back.
'67 F100 SWB STOCK.
'67 F100 SWB STOCK.
- heep70
Drivelines Northwest does that work here is WA.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- flyboy2610
re: shortening driveshaft
This is one of those "shop jobs" where the best thing to do is take it to a shop and let the pros do it. The shaft needs to be cut at exactly a 90 deg angle, the yoke has to properly aligned, the welds needs to be right so the shaft doesn't fly apart. and it needs to be balanced.
Take it to a shop.
Take it to a shop.
- 72hiboy4x4
hey greasemonkey! where you at down there? I work off St. John's and 78th. we should hook up and grab a bite sometime!
HEY no one ever answered the question about a one peice drive shaft being benificial, because I worry about two peices moving me. I'm making my rear limited slip next week and just wondered if the is any advantages.
Keep the two-piece shaft. It'll more than handle whatever you throw at it. However, converting it to a one-piece shaft will not only require a new transmission (since the one piece shaft uses a slip yoke instead of a bolt-on yoke), but the new driveshaft would end up being pretty long, and thus harder to balance and keep balanced. SWB trucks use a one-piece shaft, but there's an 18-inch difference between them and the LWB versions, so they can get away with the one-piece.
