It's always a good idea to put it as close to the front of the bed as possible and tie it down to keep it from moving. That said, as long as you have it tied down well, it shouldn't move, no matter where in the bed it's placed. You're going to have it attached securely to the cradle, so just make sure it's all secured in the bed!!robroy wrote:
A particular imaginary scenario always comes to my mind when hauling an engine. What would happen if I needed to make an emergency stop? I can imagine that it would take a serious amount of support to keep the engine from doing some somersaults right in to the back of my skull!
Since it's apparent that all of the old finish wasn't removed prior to painting the engine, it would indicate that the block was never hot-tanked prior to the rebuild, which could explain some of the problems you've encountered. Personally, I would have it cleaned properly before starting the rebuild.robroy wrote:
With the pressure plate, clutch and flywheel removed I got a better look at the back of the engine, and discovered that in it previous life, this engine block was painted red! It looks like the yellow was sprayed right over the old paint, at least on the back. I'll be very glad to get a good finish on this thing!
Also, be very careful about painting the surface where the bellhousing and spacer plate attach. Excessive paint can and will result in misalignment of the transmission to the engine. If you feel it needs to be painted, scrape it clean and just spray a thin, uniform coat of paint on that surface. Personally, I’ve always left that surface bare, as it’s protected from rusting by having the bellhousing tightly bolted against it.
Measure twice, cut once!!!robroy wrote:
I measured the oil pan about a hundred times, then got some 2x8's. I came out with a desired width of around 8 and 3/8", with a depth of 22 and 1/4".
I would, personally, make that modification to the cradle. If you’re going to have it dyno-tested (or even just test run), there will be oil in the pan. I wouldn’t want to drain that oil out until the engine has been installed in the truck and test run.robroy wrote:
My oil drain plug got a little too "custom" for its own good. Thankfully it slid right in there after I removed the drain plug! I'll have to tape the hole up before taking it for the big drive. That said, I'll need to get it home too, so maybe I need to carve a groove in the wood to clear the drain spout!
Looks GOOD!!!robroy wrote:
And here it rests, all the way in the saddle. To my absolute shock, it seems to be working well so far!!!
That’s the way it’s done on factory crate engines!!robroy wrote:
On the back you can see how the oil pan brim is digging in to the wood somewhat. I guess that's no big deal!
We never had a doubt, did you???robroy wrote:
And a side shot shows that everything lines up OK (I was amazed)!
BRAVO!!!!robroy wrote:
It looks like a nice, cozy fit!
You’re almost ready for the trip!!!robroy wrote:
Next, I'll tie it to the cradle with steel straps!
Keep us posted on any developments!!!
