Yes you're absolutely right! When I dipped my finger in the puddles and rubbed my fingers together I couldn't feel it most of the time. One time I could, but mainly not.DuckRyder wrote:IIRC you had said that you really didn't feel any grit in the puddles of oil except for one instance where you thought you felt something? So that makes me less concerned about the flakes that are causing the "metal-flake" to the oil.did you mean to type, "particularly if you can feel the metal-flake?"
I think these are good guesses! Due to the side of the windage tray that was being hit, and the direction the crankshaft was rotating, it was chipping them pieces off in a downwards motion.DuckRyder wrote: I agree, that is what I've meant when I said that they (moby and his friends) could not have been pumped up there, they are too big to go through the pump and oil passages. I suppose its possible that they slung up there but it is also possible that I'll win the powerball (but not likely if you get my drift). I think it is likely that they are due to either less than meticulous clean up after building, or perhaps the partially assembled engine was left open in proximity with other machine work. (this is just a guess though)
If I go this route, that I will most certainly do! Thanks!!!DuckRyder wrote:Well, it you are going to pull that bolt you are one bolt from having that cap off, ensure it is marked so you can reinstall it in the same direction and pull that one to inspect the bearing.I asked about the remaining stud on one of the main bearing cap bolts, and the potential for interference with the windage tray. He recommending removing the bolt and cutting the stud off!
You're right here--that studded bolt could be useful to somebody. I could toss it in with the spare rear sump and and pickup to make a "set" out of it.DuckRyder wrote:I would be more inclined to replace it with the proper bolt, it might even be useful to someone doing a rear sump conversion, although cutting the stud off should not hurt anything (don't use a cutting torch though).Although the stud's a good distance from the threads that go in to the engine, doesn't it sound a little reckless to cut one of those bolts in any way? Maybe it would be harmless.
I'll avoid the torch, thanks for warning me!
Thanks for making this explicit!DuckRyder wrote:Oh, one other thing, we should clarify "flake". I mean the silver bits in the oil that make it look like metal flake paint, not Moby.
Thanks for remaining interested and helpful despite my lack of a quick decision!Ranchero50 wrote:Just waiting to see what you decide or if you have any more questions.
Hey 70_F100, thanks for your spirited reply (no sarcasm intended there)! Below's a list of my current reasons for considering the risk. By listing them, I don't mean to attempt to convince you of the wisdom of taking the risk. I just wanted to explain my reasoning. If you're up for it, a sound rebuttal to each point (or whichever ones you want) could benefit me a lot!70_F100 wrote:With the thousands of dollars invested in this engine, WHY RISK IT????![]()
- Given the evidence, it seems probable to me that an in-truck cleanup would work out fine.
- The engine builder recommends an in-truck cleanup despite my raising the issue repeatedly.
- The engine builder may be willing to guarantee the engine for an additional length of time (this needs checking in to) if I do the in-truck cleanup. This is a big one that's still an open question.
- Since I'm still a beginner, doing this rebuild job, from start to finish, could amount to 40-80 hours of work. And it's the same work I'd need to do regardless of the condition of the engine (meaning, I could do the work when the engine's actually worn out).
- I have a pronounced dislike for re-doing work that was just done, unless I'm convinced that it's absolutely necessary. It's painful to break apart fresh gaskets.
- Since I'm not experienced, doing this work myself stands the risk of a poorer end result than leaving it as-is! This is a big one.
- I'd need to put cash in to tools and gaskets that could be deferred (until a time when I'm sure there's a problem).
Okay, I hear you on this point!70_F100 wrote:No longer than the engine has been run, they SHOULDN'T BE THERE, PERIOD!!!![]()
That's a serious prospect for sure! I guess it would help me to have some evidence as to whether or not there were more large metal flakes hiding in the engine, and tearing it down more is the only way to know.70_F100 wrote:Those metal flakes came from somewhere. There could be more of them hiding in the engine. The oil holes in the bearings are always smaller than the passages that feed them. They could be gathering on the ledges there, just waiting to break loose and jump into the lubrication stream.![]()
Good question!70_F100 wrote:The engine has had machine work done to it. Was it cleaned properly afterward?![]()
All could be!70_F100 wrote:Is there a bearing failing? Cam bearing, main bearing, rod bearing?![]()
Is there some other obscure component failing that you're not seeing?![]()
I see your point here, yet I'm a little concerned that your view of the quantity of metal here could be exaggerated. The flash on my camera turns nearly microscopic specks of metal in to the North Star, so to speak! With the naked eye, in normal lighting, that stuff's pretty invisible. I'm tempted to re-take those photos without the flash, in normal lighting.70_F100 wrote:I've built literally hundreds of engines in my lifetime, from a 3HP Briggs and Stratton, to big 149-Series Detroit Diesel Railroad/Generator engines, and even after running 500-1000 miles before the first oil change, I've never seen this much metal in the oil from a brand-new engine.![]()
Indeed, and I appreciate the opinions and evidence very much!!! I'd be lost without you guys!70_F100 wrote:Robroy, do whatever you think is right. Put it back together as-is. Flush it out and put it back together. Check the bearings and if they're good, put it back together. You've heard opinions on all of these options, all with supporting evidence.![]()
70_F100 wrote:In my humble, yet experienced opinion, if you don't tear this engine down and check everything, you're only asking for trouble. It may not show up for 30-40 thousand miles. On the other hand, the engine could literally disintegrate on a test drive around the block.![]()
True on both points, I suppose. Thanks for your honest and persistent appraisal--you could be right about all this!
Robert, Jamie, and 70_F100, thanks again for the superb replies!!!
Robroy
