My truck has the VIN F10YKB19685 (Kansas, April 1967). It has the slots and not the holes for the cowl lancing.
Roman
Cowl lacing differences!
- 4x4x4crewcab
re: Cowl lacing differences!
A 67 F100 a friend and I parted out was A44,*** NOV/66 Kansas City built and after going back to the photos it had the round holes
Mark
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
1999 Ford Windstar
Its possible that the change didn't occour in all plants at the same time, although would think it would be within a month or two at the most...
Wonder what a 66 looks like?
Yeah, I'm sure that's how they did that. Each plant just used up the existing cabs until they ran out and the new ones arrived, so depending on each plant's production numbers it would probably vary a little bit. But like you, I wouldn't think there would be more than a couple month variation between plants.DuckRyder wrote:Its possible that the change didn't occour in all plants at the same time, although would think it would be within a month or two at the most...
- flyboy2610
Sounds like any one with a '67 should double check what style mounting the cab requires. Could go either way
Yep, once we get this figured out I'll have to make another entry on the Pickup ID page.
- mk
I wonder if the cowl sheet metal change was made at the same time they stopped stapling the buck tags to the firewall. Seems to me it was around April 67 when the tags disappeared...
mike
mike
