Never had a problem with it. I did buy seals and gaskets and I am not planning on a rebuild, but it is out of the truck and cleaned up. Is there any reason to rebuild of should I just replace gaskets and seals and slap it in?
Thank you for the input.
Should I rebuild my NP-435 Transmission?
- bjde0b
Re: Should I rebuild my NP-435 Transmission?
check your shaft play and see if the bearing seem worn. if they are tight i wouldn't worry about it. if they are real loose you would want to do something to it.
- bjde0b
axial or radial? Would you recommend cleaning out the casing even if I don't do a rebuild?
Check out my build. http://s1088.photobucket.com/albums/i336/MyF100/
eitrher way. and you could drain the fluid and dump some gas or something through it to clean it i guess.
