aod got me stumped
BobbyFord
Re: aod got me stumped
Post by BobbyFord »
It should at least have something. Are you sure the linkage is actually moving the valve body?
flatblack
Post by flatblack »
i know, i have even shifted it manually by putting the e brake on and trying all gears from underneath. still nothing
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
mmerlinn
Post by mmerlinn »
Did you drop the pan to make sure that the linkage is actually hooked to the valve body?
mrsnicks
Post by mrsnicks »
I read on a mustang AOD swap article that if you go from a floor shift to a column shift you have to rotate "something" 180degrees.... But yeah, like mmerlinn said check that it's connected inside.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
