Drain Transmission to install cable?
Lar4t9r
Post by Lar4t9r »
My 1969 F 100 did not have a speedometer cable in it when I got it. I now have a cable assembly, but need to know if i have to drain the transmission fluid to install the cable on the tranny side. The old end is in the trans and has the clamp type retainer. It has a rubber cap over the end of it and when I pulled that off, some tranny fluid ran out so I pushed it back on. I did a search here but could not find an answer. Any help would be appreciated.
:fr:
Laurence (Proud owner of 1969 Ford F-100 and 1970 GTO)
michael69
Re: Drain Transmission to install cable?
Post by michael69 »
You don't have to drain trans to replace cable but you will lose a little fluid when doing it.Just have some cardboard laying under truck and some rags handy.
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
Joshpow
Post by Joshpow »
:yt: It may also help to park the truck with the drivers side uphill to keep the lost fluid to a minimum. I would route it in and have it ready to pull the old stub out and put the new cable right back.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
Lar4t9r
Post by Lar4t9r »
Thanks for the info, guys. I'm off to see the wizard...let you know how I made out.
Lar4t9r
Post by Lar4t9r »
Well I got it installed easy enough. But when I pulled the stub out of the trans, I found the nylon gear was chewed, so obviously, I need a new one before it will work. Always something... :cry:
count the teeth before getting a new one. the tooth count is what makes your speedo read correctly. unless you have different sized tires than stock size then you need to do a calculation to figure the number of teeth you need to get it to read right.
Lar4t9r
Post by Lar4t9r »
fordman wrote:count the teeth before getting a new one. the tooth count is what makes your speedo read correctly. unless you have different sized tires than stock size then you need to do a calculation to figure the number of teeth you need to get it to read right.
Yes, I knew that Fordman. Stock tire size and rearend. My C4 tranny uses a 16 tooth gear. Already ordered one. :thup:
thats good . i was just making sure. its ahrd to know what everyone else may already know. i have seen a few guys come back and ask questions after they thought they had it figured out. so i was trying to eliminate another question. maybe some one else will see this and need this info.
Joshpow
Post by Joshpow »
Always some surprise behind every job! Glad the info helped.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
Lar4t9r
Post by Lar4t9r »
fordman wrote:thats good . i was just making sure. its ahrd to know what everyone else may already know. i have seen a few guys come back and ask questions after they thought they had it figured out. so i was trying to eliminate another question. maybe some one else will see this and need this info.
You are right, sir! With that in mind, here is a site that provides formula for the gears, and you can buy the correct one for your transmission.
http://www.tciauto.com/Products/TechInf ... _gears.asp
Ford gears at at the bottom of this page. Once you determine which gear is correct for your application, you can click on a link for the part number and buy the gear. There are other sites out there, this just happened to be a link I had saved.
thats cool thanks for that link. this issuse has came up before with the spline count thing.
Lar4t9r
Post by Lar4t9r »
Gear came in yesterday and i put it in today. Works fine, I have a speedometer again! :woohoo:
