Comparing 427, 428, and 429 (help)
427
Re: Comparing 427, 428, and 429 (help)
Post by 427 »
I have a 64 model r code 427 in my truck and it has 352 stamped on the block. I think about all F.E. motors are stamped 352?
68 f100 427 r code 4spd toploader
69 f350 390 4spd hauler bed
72 Ford Bronco 302 3spd
95 Ford Lightning
38 John Deere G
Assorted old Honda ATC,s
sideoilerfe
Post by sideoilerfe »
427 wrote:I have a 64 model r code 427 in my truck and it has 352 stamped on the block. I think about all F.E. motors are stamped 352?
Most are but not all.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
averagef250
Post by averagef250 »
I have a 74 360 block that actually has 428 cast in the front where they usually say 352. I've also seen a 63 390 block that had 406 cast in the lifter valley and had the bosses for crossbolts (unmachined of coarse).
