spark plug wire sequence
emilo2008
Post by emilo2008 »
i need a diagram for a 352.360.390 if you guys have one.thanks
Re: spark plug wire sequence
it should be on the manifold but here is one i got off of here awhile back.
thebannister8
Post by thebannister8 »
double check on your manifold though... :2cents:
emilo2008
Post by emilo2008 »
it wants to start up but my solenoid keeps getting hot and the wires.does anyone have a diagram too.
that wasnt a very good diagram. sorry about that try this one.
sacramento_ford
Post by sacramento_ford »
fordman wrote:that wasnt a very good diagram. sorry about that try this one.
thanks fordman. i dont need to post for that, i took my wires off to take em back and thought i could figure it out, thing was poofing fuel out and not staring. ,,,
that is back firing through the carb and that means the dist is too far one way or another. or the timing chain is gone out or jumped.
willowbilly3
Post by willowbilly3 »
or the plug wires are off.
Excessive heat on the solenoid/wires means too much resistance, probably a poor connection or maybe you just cranked too long. I think the proper amount of cranking goes something like, crank 20 seconds, wait 2 minutes. Of course non of us follow that when we are having issues.
emilo2008
Post by emilo2008 »
dang i have the firing order right.any more suggestions it turns on for about 3 seconds then dies. the car throttle is hard im going to take it off and go from there.im getting fuel does anyone have a diagram on the vacum lines?
