Engine Clean up
69rangerf100
Engine Clean up
Post by 69rangerf100 »
Here is another Question that i have. i am getting ready to start the rebuild on my engine. i have it completly torn down to the bare block and i want to get all the old paint off of it. what is the easiest and least expensive way to strip the paint off of it?
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
Re: Engine Clean up
if not taking to a machine shop for "vatting" (which really isn't usually vatting anymore)
aircraft stripper, simplegreen, super clean and a pressure washer... (remove the sircraft stirpper befor the pressure waher obviously...)
knightfire83
Re: Engine Clean up
Post by knightfire83 »
When I start a major engine project I first use a pressure washer to get all the oil / grease / nastiness off of it. Then it is taken all apart and every piece is cleaned with wire wheels in a drill. You can get an assortment pack of various sizes and types of wheels at Harbor Freight or places like that rather inexpensively. Once that is done everything is nice and clean and about 95% of the paint is off.
After all the machine work is done and the engine is reassembled, clean off any remaining oils with brake cleaner then it is ready for paint.
Rather time consuming, but the rewards are worth it...
1974 Ford F-100 4x4- 360 / manual.
1970 Ford F250 4x4 ~ Sold.
thebannister8
Re: Engine Clean up
Post by thebannister8 »
gunk and a wire tooth brush, paint stripper and a wire tooth brush..they help too :2cents:
1967AceStroker
Re: Engine Clean up
Post by 1967AceStroker »
If you don't mind taking it to a engine machine shop, have them hot tank it for you. It don't cost very much, it was I think $15 to do just my heads. And it will come out clean, clean, clean!
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
69rangerf100
Re: Engine Clean up
sounds like the machine shop would be my best bet. know i just have to find one around Dallas, GA
David
FreakysFords
Re: Engine Clean up
Post by FreakysFords »
69rangerf100 wrote:sounds like the machine shop would be my best bet. know i just have to find one around Dallas, GA
If I can recall the name, you have a very good one in Austell!
OK, racked my brain and can't think of the name, but look 'em up in the area and it's on 6, close to a car lot as I recall. I drove all the way from here cause they stand behind their work.
