How Do I get the steering wheel off?
67_F100_390
Post by 67_F100_390 »
Ok I have the taken off the nut behind the horn and i cant get the steering wheel to budge. Is there a way I can get this steering wheel off without going and buying a puller for it? By the way its the factory wheel that came on a 67 F100.
floyd67
Re: How Do I get the steering wheel off?
Post by floyd67 »
if you pull up on the wheel real hard and hit the steering shaft the wheel should pop off you have to be carefull not to damage the shaft or youwill not get the nut back on
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
papabug71
Post by papabug71 »
If it hasnt been of in a long time, or ever, it might take a little elbow grease. Keep tapping on it, or bopping on it if you will while pulling up. Worked for me.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
A steering wheel puller is only $7 or $8...why not just buy the correct tool? :hmm:
BobbyFord
Post by BobbyFord »
FORDification wrote:A steering wheel puller is only $7 or $8...why not just buy the correct tool? :hmm:
Agreed, but...if trying to muscle it off, make sure you leave the nut on a couple of turns or you'll be taking a trip to the dentist...
67_F100_390
Thanks guys i got it off with a brass punch and hammer gave it a couple good taps on the thead and it came right off.
you got lucky i think. this is the worst job i have ever done on any of these trucks. and i hate it. i use a puller with a impact to zip them off when i have to pull them now. that is the only way i can seem to get it done. by hand makes the puller tilt on me for some reason. even though the puller bolts are in there an equal length and all of that.
Banjo
Post by Banjo »
best way I have found short of a puller (like at a yard and you find one and don't have pulled with you) is spray shaft w/penetrating oil, leave nut on a few threads and put a palm on each side across from one another and bang with your palms kinda impacting and rotate around keeping your hands opposite of one another. will hurt your palms for awhile, as it's tough, but it can be done if you're a long way from a store and have no handy puller and really have to have it. I've done this 2 or 3 times and it hurts, but will work. If it weren't an emergency, I'd go borrow a puller for free from a chain autoparts store on the loaner tool program. They have tons of tools like that which are free to borrow.
Brisco Darlin'......"You sure do render good Sheriff!"
thebannister8
Post by thebannister8 »
leave the nut on the shaft and leave a little room for the wheel to move and hit the nut ( not too hard )..otherwise with no nut you'll be filing the threads so you can get the nut back on. i couldn't get mine off by jarring it like this, but it came off with ease with a puller...a puller is a great tool for your toolbox :wink: ..... :2cents:
oh no. i've done that before and i have damaged the threads anyway. so i won't do that any more either.
Camper Special Ed
Post by Camper Special Ed »
thebannister8 wrote:leave the nut on the shaft and leave a little room for the wheel to move and hit the nut ( not too hard )..otherwise with no nut you'll be filing the threads so you can get the nut back on. i couldn't get mine off by jarring it like this, but it came off with ease with a puller...a puller is a great tool for your toolbox :wink: ..... :2cents:
:yt: :2cents:
1970 Ford F-250 Camper Special. 351 Clevland V8
1971 Ford F-100 Stepside Pre Runner. 460 CI V8
1962 Ford F-250 Factory Flatbed. 292 CI V8
1989 Ford F-350 Dually. 460 FI CI
1968 Dodge Charger (General Lee) 318 V8
1959 GMC 101 Stepside. 350 V8
1957 GMC 100 Stepside. ( in a Million peices)
1959 Chevy Panel. 350 CI V8
