Hard To start ... Update
- 1971fordcustom
Ok guys I have a 360 with a 2bb carb. I've rebuilt the carb about 2 months ago and put a manual Choke on it wile I was at it. Well for the past 2 weeks It takes me at lest 10 mins to start that truck and even when it warm it take 3 mins, I have to crank let it rest and crank some more.
Im getting gas to the carb no problem, I have good spark, I've took a look all the vacuum hoses, I am replaceing the vacuum advance today. Woud it be my Points? or im not getting any Compression it does have hunderd in 3000 miles on it. Timeing? It wants to die if im not moveing down the road at a good speed. When its in Park the thing Idles great but not when im in gear. Idk what to do any more.
Last edited by 1971fordcustom on Sat Feb 28, 2009 3:29 am, edited 1 time in total.
http://s205.photobucket.com/albums/bb31 ... d%20F-100/
1971 F-100 Explorer Special custom
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1960 Ford F-750 FireTruck
1960 Gmc 6000 FireTruck
1962 IH R-185 Firetruck
1959 Ford Custom 300
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
- AlleyCat
Re: Hard To start ...
I'd suggest you start by checking fuel ines and make sure the choke is closing when you try to start it. After that take a good look for vacuum leaks. Since you recently rebuilt the carb and you have a hard time keeping it running at low engine speeds tells me to suspect a vacuum leak.
Clay
- 1971fordcustom
I've all ready done ever bit of that.AlleyCat wrote:I'd suggest you start by checking fuel ines and make sure the choke is closing when you try to start it. After that take a good look for vacuum leaks. Since you recently rebuilt the carb and you have a hard time keeping it running at low engine speeds tells me to suspect a vacuum leak.
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
- AlleyCat
Have you hooked up a vacuum gauge to get a reading? Also yes, by all means check the timing and points.
Clay
- willowbilly3
Did you put on a manual choke carb or just a conversion kit?
Without exception, every conversion kit ever sold is totally junk. The first time you pull the choke without holding down the gas pedal, the whole think kind of collapses and is no longer functional.
- 1971fordcustom
I got the conversion kit. I Took it apart today and it seems fine.willowbilly3 wrote:Did you put on a manual choke carb or just a conversion kit?
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
- willowbilly3
It will still look the same, the cable housing slips in the clamp that's supposed to hold it. Maybe this isn't your problem right now but it's still junk, believe me.1971fordcustom wrote:I got the conversion kit. I Took it apart today and it seems fine.willowbilly3 wrote:Did you put on a manual choke carb or just a conversion kit?
- thebannister8
check and make sure the little balls in the carb are in the right holes
- 1971fordcustom
I don't have a vacuum gauge I can use one from my friend's but I hate useing any thing thats not mine.AlleyCat wrote:Have you hooked up a vacuum gauge to get a reading? Also yes, by all means check the timing and points.
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
- 1971fordcustom
willowbilly3 wrote:It will still look the same, the cable housing slips in the clamp that's supposed to hold it. Maybe this isn't your problem right now but it's still junk, believe me.1971fordcustom wrote:I got the conversion kit. I Took it apart today and it seems fine.willowbilly3 wrote:Did you put on a manual choke carb or just a conversion kit?
Well I wont for get that if I have some Choke Problems.
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
- AlleyCat
I hate to borrow things myself but it might benefit you to borrow your friend's gauge. On a carbed gas engine a vacuum gauge can be a big help when troubleshooting problems.1971fordcustom wrote:I don't have a vacuum gauge I can use one from my friend's but I hate useing any thing thats not mine.AlleyCat wrote:Have you hooked up a vacuum gauge to get a reading? Also yes, by all means check the timing and points.
Clay
- 1971fordcustom
Re: Hard To start ... Update
Well Today I got the vacuum advance installed and put new points in. Now the truck run soooo much better. When the engine is warm all I have to do is bump the key and it fires right off. No more wanting to stall in gear.
Thanks for all the help guys
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
- drytoast
Nothing better than a good running truck.
Life is hard; its harder if your STUPID. John Wayne
1972 Ford F-100 Explorer 302 C4 automatic
2005 Chrysler T&C Limited
1996 Honda Accord LX 238,000 miles and counting
- 1971fordcustom
drytoast wrote: Nothing better than a good running truck.
YUP By the way NICE NAME
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
