73 dana 60 3.53 posi any value drum to drum complete
- bigdoug22
just ran into one today gotta look at everthing, this new truck is becoming an illness. Just pulled a set of matching red seats colorwise all leather dual electric seats from a 83 Lincoln Mark V!!. HELP
72 f250 camper special and it only cost 200.00 and it has now soared over the $1000 mark
re: 73 dana 60 3.53 posi any value drum to drum complete
Well, the rearend assembly as a whole won't work for the '67-'72 trucks, due to it being wider....unless you relocate the spring perches. However, by doing so and using this assembly will allow your rear tires to track behind the fronts, something they're not doing now. Otherwise, AFAIK the carrier should be swappable into the earlier Dana 60s. Either way, it's definitely worth saving.
- Redcap
I'd hang onto it just for the 3.54 gears and the LSD.
- willowbilly3
Keith, were the F-250s narower too? I assume a 73 Dana 60 to be a 3/4 ton. I know th pads would be closer together (unless it came from a highboy) but what about overall width?
Hmmm....AFAIK all '67-'72 F100/F250 rearend assemblies are narrower in width, whereas all '73-'79 rearend assemblies are wider in total width and also have the spring perches farther apart due to the wider rear frame. However, the '73 thru '77-1/2 Highboy rearend assemblies, even though they're still wider overall, have the same framerail spacing as ours so those would have the perches in the right spot, making it a bolt-in for our trucks.
