OT 2002 Ranger exaughst question
OldRedFord
Post by OldRedFord »
Have a crack in the Y pipe on the Ranger. Its cracked right at one of the oxygen sensors.
Thought it was something else when I had taken the truck to Advance and Auto Zone and couldnt pull up a code. So I took it to the stealer.
I should also point out that my truck has no muffler and just has a turn down behind the cat.
But anywho they said the rattle I have going on is because of not having a muffler and that one of the cats in the Y pipe has a loose chunk inside it.
They said it would be $1700 in parts to fix it all. For right now I am just going to weld up the crack. I also am hoping that will fix the rattle. I think its just loose cause of the cracked pipe.
But the major point of my post is....
Should I weld up that crack before I drive it anymore? I have heard that if the engine is running lean you can burn up the pistons. Is this true?
Kinda need to know tonight so I can decide what I am going to do tomarrow.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: OT 2002 Ranger exaughst question
i/d just weld it up myself. i wouldn't worry about it. i'd weld it up before it got any worse.
