C4/C6 Speedo gear?
- rjewkes
C4/C6 Speedo gear?
Is this gear the same or will i eed the gear for a c6 i just swapped out a dead 302/c4 for a very much living Firebreathing dragon of a 390/C6 combo.
fuelly.com
fuelly.com
Re: C4/C6 Speedo gear?
Should be the same driven gear. However that does NOT mean that it will work properly.
If your new C6 does not have the same speedo count on your output shaft as your C4 did, your driven gear will not register the correct speed even though it will install and work.
- rjewkes
Yup i got the engine in and running. needs a little tlc but runs.
fuelly.com
fuelly.com
