C4/C6 Speedo gear?
rjewkes
C4/C6 Speedo gear?
Post by rjewkes »
Is this gear the same or will i eed the gear for a c6 i just swapped out a dead 302/c4 for a very much living Firebreathing dragon of a 390/C6 combo.
fuelly.com
mmerlinn
Re: C4/C6 Speedo gear?
Post by mmerlinn »
Should be the same driven gear. However that does NOT mean that it will work properly.
If your new C6 does not have the same speedo count on your output shaft as your C4 did, your driven gear will not register the correct speed even though it will install and work.
you got it in and running?
rjewkes
Post by rjewkes »
Yup i got the engine in and running. needs a little tlc but runs.
fuelly.com
