Who would reuse this axle?
- Hawkrod
Re: Who would reuse this axle?
Not me man, I would walk before I risked using that axle! Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- ares360
never seen anything like that.
Kane
1971 Ford F250 4x2, no engine.....what am I going to do?
yea it has the wear on the axle also. i suppose it could be welded and machined. but that is a chance of weakingthe metal through metal fatigue even more.
- SteveC
wow least it didnt look like a toothpick. but ya you see some scary thing po do to their trucks
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- averagef250
Seen that a few times myself. I've stuck them right back in when customers didn't care to pay for a new axle. Never had one come back.
Right way- replace it.
- Joshpow
Axles are too plentiful for me to knowingly trust my trips to a damaged one. I'd try to replace if I could round up money for an axle.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- willowbilly3
Same here-seen it a lot but never had a broken axle come in that had the torch marks on it. I surely wouldn't use it for high hp or heavy hauling though.averagef250 wrote:Seen that a few times myself. I've stuck them right back in when customers didn't care to pay for a new axle. Never had one come back.
- flyboy2610
Holy Crappenpoopen, Batman! Some peoples parents should never have had kids!
- bjde0b
Nobody has answered the second part. I need a short shaft for a 9" ford in Houston. Surely somebody has one lying around.
Check out my build. http://s1088.photobucket.com/albums/i336/MyF100/
i don't have any parts rearends. and i'm no where near houston. maybe a parts wanted ad might get more readers.
It's probably still stronger than the other end-unless you have 31 spline axles. It probably would run a long time....but it is a drag to have your wheel sticking 3' outside the fender.
Somebody was a real hack with that torch. I've cut a lot of old bearing races off without damaging the shaft.
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
55F100
- ContryboyFE
i've got a 9 in in my parts truck. its a 69 stepside. i live near stl in missouri though. pm/email me if you interested.i've got some pics at http://photobucket.com/countryboyFE but i dont think i have any of the rear endbjde0b wrote:Nobody has answered the second part. I need a short shaft for a 9" ford in Houston. Surely somebody has one lying around.
ben
webbconstruction4drywall@gmail.com
'68 F100 step-side - sitting idle for now
'05 Expesition Limited 4X4 -DD gorcery getter & toy hauler
Our truck's rearends don't have a long/short axle shaft....they're both the same length: 29-7/8"
- Hawkrod
Just out of curiosity, are you in the habit of removing the bearings from broken axles stubs to check? The damage was under his bearing and if an axle broke the retainer is destroyed (even when the axle does not come out) so you normally would not remove teh bearing to see so I really wonder if you checked them all to be able to make that statement. Hawkrodwillowbilly3 wrote: Same here-seen it a lot but never had a broken axle come in that had the torch marks on it. I surely wouldn't use it for high hp or heavy hauling though.
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- willowbilly3
Yes, whenever something is broke I do inspect the fractured part and I'm sure I would see it broke where there was prior damage. I always want to know why something failed and will disassemble it too if I need to satisfy any curiosity. It's very rare to see one broke off at the bearing for any reason in a general repair shop. I have also witnessed axles with a lot more severe torch damage than that which were still in service. Keep in mind some of us have wrenched in very remote locations, just couldn't run to the parts counter, and we had to make work with what we had. I even mixed ring and pinions from different sets once when I was working in a camp above the Arctic Circle because it's all we had. And it worked, the truck was still going after several months in pretty severe service, when I left. But everyone who thinks they know will tell you that you can't do that.
