Brake upgrade question
I was reading the brake upgrade write up posted on the main page. I didn't see the issue of a different pedal being discussed. The Mustangs had a different pedal for power and manual brakes as well as disc/drum brakes. Did the trucks just use 1 pedal for everything ?
Re: Brake upgrade question
yes the pedals on our truck is all the same. the only reason to change otu your pedal is if you are going from auto to standard transmission. or the other way around if you want to get rid of your clutch pedal.
Awesome !
