'69 to '76 speedo question?
green68250
Post by green68250 »
I was wondering what is nessesary to get a '69 speedo to work with the cable that comes out of my '76 NP 205 T-case? The guages on the '76 used a push in style connector on the back of the speedo and the '69 uses the screw in method. Is there a way to convert the two? What are my options?
Thanks for the help,
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
Re: '69 to '76 speedo question?
get a different cable. as far as i know those 76 cable ends cant be made to work that i know of.
mljjones67
Post by mljjones67 »
I will have the same problem here soon. I will watching this thread for an answer I hope! :D
green68250
I hope there is way to make it work. I just thought about cutting both cables in half a joining the them together somehow. Basically have the '76 end comming out of the transfer case and the '69 end going into the speedo. Unless there is a special conversion, this is the best I have heard so far.
Corbin
willowbilly3
Post by willowbilly3 »
I used to have a parts store in Anchorage that made them up, any ends and any length you wanted. I want to believe it is still possible.
its been awhile since i have seent he 76 cable that goes into the trans. post a pic and refresh my memeory please. i think i have a solution but i need to see which end you have in that trans.
green68250
I found a place that custom makes speedo cables so I think I will check them out. I haven't had time to go out and get I pic of the end yet hopefully soon. Its not a big problem yet I still have to swap bodies and reseal my 390.
Corbin
thats cool im glad you found a place.
Fordnatic
Post by Fordnatic »
There used to be things such as speedometer shops. When I put my toploader in my '70, the long tailshaft made the original cable too short. I had them make one up. They had a roll of generic cable and could put whatever ends on you needed. They even had the right gear to make my speedo accurate. It was a little shop with dismantled speedo's everywhere. I'm sure speedo shops have gone by the wayside now. Too bad.
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
