HDMX- FMX trans
67camper
HDMX- FMX trans
Post by 67camper »
hey all,I heard all the parts are same except the case. :? was looking to rebuild my HDMX at school if parts are around. any knowledge about it would be great. thnx :fr:
60 percent of the time it works every time
FordTruck
Re: HDMX- FMX trans
Post by FordTruck »
I got a whole FMX if you want :lol: it I pulled it last year from my 70
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
Re: HDMX- FMX trans
i have a complete working mx trasnmission it is from a 67 it also has the watercooler for the tranmission lines.
Hawkrod
Re: HDMX- FMX trans
Post by Hawkrod »
67camper wrote:hey all,I heard all the parts are same except the case. :? was looking to rebuild my HDMX at school if parts are around. any knowledge about it would be great. thnx :fr:
Sadly almost none of the parts are the same between the MX and FMX, The FMX is an evolution that combined the internal strength of the MX in the size of the FX but very little actually carried forward from the two older designs. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
mmerlinn
Re: HDMX- FMX trans
Post by mmerlinn »
Not true. Most MX and FMX parts look identical and most are even hard to tell apart even when you measure them. But, if you try to mix and match them you will end up with a real mess that won't work.
67camper
Re: HDMX- FMX trans
Post by 67camper »
so it sounds like stuffing fmx cluthes and bands etc. into my MX is abad idea :hmm: . I also got a C6 behind a 351W, will that bolt up to an FE?
Re: HDMX- FMX trans
fe is a differnt bolt pattern than the 351w
swissranger
Re: HDMX- FMX trans
Post by swissranger »
I do not know if some of MX-HD and FMX parts are the same. One main difference between these automatics is that the MX-HD has a second oil pump direct on output shaft. Due to this it's possible to start the engine thru pushing the truck. :thup: FMX trannys don't have this pump.
Roman
mmerlinn
Re: HDMX- FMX trans
Post by mmerlinn »
67camper wrote:so it sounds like stuffing fmx cluthes and bands etc. into my MX is abad idea :hmm: . I also got a C6 behind a 351W, will that bolt up to an FE?
Nope. Wrong bell housing bolt pattern.
67camper
Re: HDMX- FMX trans
Post by 67camper »
man, thats a bummer..
Re: HDMX- FMX trans
here a c6 disassembly chart maybe you could rebuil done of these for school.
67camper
Re: HDMX- FMX trans
Post by 67camper »
awesome :thup: thnx fordman
