Exhaust manifold bolts
Faltura
Post by Faltura »
The two bolts on the top passenger side exhaust manifold that hold the heat riser for the air intake are different from the others. Does anyone know where you can find replacements? It is threaded on both ends and has a nut about 1/4 of the length from the outside end.
Dragon
Re: Exhaust manifold bolts
Post by Dragon »
Faltura wrote:The two bolts on the top passenger side exhaust manifold that hold the heat riser for the air intake are different from the others. Does anyone know where you can find replacements? It is threaded on both ends and has a nut about 1/4 of the length from the outside end.
That was for the warm air induction box.
If you don't have it don't worry about them unless you are going for Concours stock look.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
if you are wanting those exact bolts. what they are. they are studs with nuts on them. any parts store will have studs and nuts.
Dragon
Post by Dragon »
Don't use Home Depot grade bolts. There are much better lower rusting grades available.
Old Fords Rule
My Gallery
Spark test
