Correct speedometer gear
mrtleavitt
Re: Correct speedometer gear
Post by mrtleavitt »
You guys can continue to duke this one out but any Ford dealership stocks many kinds or speedo gears. The manual tranny gears are different from the automatic gears. However, very many of the manual tranny gears are the same such as the NP435, T18, and T19. Those I know for sure. I can not remember exactly but I think anything from 15-19 tooth gears are available. FYI- a T19, T18, and NP435 with 3.0 diff gears and 31' tires needs a 15 tooth gear.
the lazy way to get this probelm taken care of. is to drive down the highway at 60 miles and hour. when you get to the first mile marker post look at the second hand on your watch. if the gear is correct then your trip to the second mile marker post will be 60 seconds. if it isnt then you adjust your speed to the next post until you figure out how far the speedometer is off. then just drive either 5 miles an hour faster or slower than the speedo reads.
mmerlinn
Post by mmerlinn »
Dragon wrote:The diameter of the drive gear changes the ratio because it is a right angle worm drive not the drive teeth count. If we hit it at an angle or parallel to the Drive shaft then the teeth count would matter. But we hit it in all cars straight on the end so the diameter matters. Larger the diameter the slower it appears to spin.
Not true for speedometer gears although it IS true for ALL other gears.
With speedometer gears from ANY OEM there are usually about 3 different diameters and dozens of tooth counts. All gears of the same diameter will work with the SAME drive gear(s), but the ratios will depend on the number of teeth.
Hawkrod
Post by Hawkrod »
mmerlinn wrote:snip
snip
That is not correct. Toothed gears of any kind work exactly the same and it does not matter what the diamters are, it is only the tooth count that matters. For example, you can have two gears with 20 teeth that are 4 inches in diameter, the driven gear will turn the same number of times as the driven gear. You can have two other gears both with 20 teeth but one is 6 inches in diameter and the other is 4 inches in diameter and the driven gear will still only turn one time for each time the drive gear turns. You can't skip teeth. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
SteveC
Post by SteveC »
use this formula
New Teeth = (Current Teeth x Speedo Reading)/Actual Speed.
so for me i had a manual with a 18tooth gear in it and my speedometer was reading faster than i was accually going so if it said 30 i was about 25(clocked on gps)
so NT=(18 x 30)/25 so that says i need a gear with 21.6 teeth round that to 21. I couldnt find a 21 tooth gear so i went to a 20tooth
Now using the gps methaid and the counting the mile marker, also clocked my self with one of those beside the road speed indicators. i am about 1-2 miles off on the speedometer.
though i think if you get some redicious number of teeth you need to change the gear inside the transmission or transfer case
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
Hawkrod
Post by Hawkrod »
SteveC wrote:use this formula
The sad thing is that on some trans the drive gear is actually part of the output shaft and you have to change the shaft to change the gear. Talk about a major hassle! LOL If you ever do run into that problem you can go to a speedo shop and they will fix you up with a speedometer drive adapter, it is just a little box with gears in it that can be used to correct cable speed when the trans gears can't. You most often see these on big trucks but HiPo Fords of the late 60's had them if you ordered 3.91 or 4.30 gears. hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
SteveC
Post by SteveC »
thats right i forgot that some transmissions had those gears built into the output shaft.... good info to know though thanks hawkrod
1967 f-100 4x4
fomocoguy
Post by fomocoguy »
Hey, that's very helpful! Tomorrow I will pul the gear and see what I've got. Thanks!
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
SteveC
Post by SteveC »
no prob for me finding the right gear was easy.... finding the right speedo cable was a complete pain... ended up having to order one for a bronco....cause the speedo cables wernt the kind that had the gear held on with a c clip on the small stub end.
Glad i could help you
1967 f-100 4x4
