Here is a clip I made a few years ago.
http://www.youtube.com/watch?v=Dpvla8pK1T4
A ride in the ol hot rod.
Forum rules
Videos are only allowed in the Video Gallery forum....not in a post in any other forum. Videos posted to any other will be immediately moved as needed. One video per thread, please! Nothing allowed of an adult, political or religious nature. For further rules and how-to's, click here.
- Freightrain
Bump'n along.
- seattle67
- Joshpow
Re: A ride in the ol hot rod.
Cool ride. I like that video.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- Freightrain
Wish I could have actually mounted the camera, as if I would have really got on the throttle............it woulda just flew around the cab....
Bump'n along.
- craftsman
- Freightrain
Thanks.....yup, wide ratio toploader with 4.56 gear out back.
Bump'n along.
4.56 gear wow whats your top speed in that thing? mine will only get to a little over 100mph with 3.70 well thats what it says on the tag.
- 69twotone
Where did you pick up your gear shift lever and handle? That is much cooler than the old ball with the numbers on it.
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
- Freightrain
It will pull 100 mph in the 1/4 mile, so that's good enough for me. With those little 3 1/2" front runners I don't like to push it. It's pretty heavy on the nose and even with a swaybar it's very hard to get around corners, especially with a full spool out back. The rear tires are 28x12.5 M/T.
The shifter handle is a gennie Chrysler piston grip I got back in early 80's at a swap meet for $15. Can't recall what body style, A, B, what? It was a pretty long one, so I had to cut a few inches off the bottom and redrill the mounting holes. I still have the cutoff piece to reassemble if need be. It's very comfortable to drive as it's just at the right spot. To buy that shifter these days would set you back a few hundred bucks. I think you can get repops now too.
Bump'n along.
