![Hmmm :hmm:](./images/smilies/icon_hm.gif)
302 engine stands
- michael69
302 engine stands
When swapping out FE stands which is manual steering. For 302 and power steering do I bolt the 302 stands where FE stands were or do I have to move them back so power steering will clear them
.It is a 1969 2wd. I read where bottom holes has to be drilled but don't know if I am needing to move stands back to the back holes already in frame. Thanks For Any Answers.
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
Re: 302 engine stands
the small block perches go in the front set of holes. so the steering box isnt a factor when using a small block.
- michael69
Are you calling the front the ones from the grill or the cab?
![Confused :?](./images/smilies/icon_confused.gif)
Michael69
- michael69
Thanks I thought that was what you meant but wanted to make sure and look like a dumb butt. THANKS AGAIN
Michael69
The top of the driver's side stand has to angle forward to clear a Saginaw power steering pump and so will use the forward set of holes. The passenger side uses the rear set of holes. Just bolt the stands in with the upper bolts and use the stands as a template for drilling out the crossmember for the lower set of holes.
