drive shaft
BlueOvalDave
drive shaft
Post by BlueOvalDave »
Is there a one piece drive shaft that will swap in place of the two piece in a 67 F-100 :hmm: anyone have any experience with this?
:fr:
Re: drive shaft
you could look at the dentsides. it might work. i havent done much on measuring on the driveshafts. but you measure them from center of ujoint to center of ujoint. and then measure both yokes to see if they are the same length. that should give you a total to see if any fit.
SteveC
Re: drive shaft
Post by SteveC »
isnt there a problem with puting a one piece shaft in place of a two piece?? wont the ont piece have a tendancy to "whip" or vibrate bad
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
Re: drive shaft
they must have solved that problem with the dentsides. because all of the 2wd lwb dentsides i have seen all had a one piece. i do remembeer hearing something abotu what you are talking about though. but i dont remember what it was.
BobbyFord
Re: drive shaft
Post by BobbyFord »
SteveC wrote:isnt there a problem with puting a one piece shaft in place of a two piece?? wont the ont piece have a tendancy to "whip" or vibrate bad
Don't know about the bumps but my 63 uni longbed, 390/C6 has a one-piece driveshaft and has been paced by a known good speedo in a new car at 120 mph with no vibration.
SteveC
Re: drive shaft
Post by SteveC »
hmm could just be still sick and imaging things then LOL pay me no mind.
Though i have heard that you have to be carfull with that kind of stuff
1967 f-100 4x4
Thunderfoot
Re: drive shaft
Post by Thunderfoot »
Yep, the 79 LWB I scrapped had a 302/C6 with one piece driveshaft... the only thing with it was the trans had a slip yoke in it instead of the yoke mounted in the trans. You can convert over to a 1 piece but you will have to convert over the trans for the slip yoke as well. This is one reason for the 2 piece driveshaft as the slip yoke is in the shaft not the trans.
Some of the newer crew cab short bed trucks (gm) switched to a 1 piece shaft to get rid of some vibration problems from the 2 piece they had before. :2cents:
Anyway, Hope that make sense...
Shayne
BlueOvalDave
Re: drive shaft
Yup, that all helps :thup: It's a 302 with a C-4 so I'm gonna scrounge the boneyards and make something work :wink: :fr:
BobbyFord
Re: drive shaft
Post by BobbyFord »
Forgot to mention the uni has a car-type slip yoke trans.
Hawkrod
Re: drive shaft
Post by Hawkrod »
Only the lightest duty Ford long bed trucks got oe piece shafts, all the heavier ones got a two piece shaft. Do a search, we discussed this subject a while back and a lot of facts were posted. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
mrtleavitt
Re: drive shaft
Post by mrtleavitt »
I can't remember the cut off point but most driveline shops recommend not going over a certain lenght for a 1 piece. I'd be a little skeptic myself, but you're not me. :lol: Give it a shot!
FordTruck
Re: drive shaft
Post by FordTruck »
When I swapped out my 302/FMX combo for a 302/C6. The truck had a 2 pice with a slip yoke on it and the truck the C6 came out of was a 2 pice slip yoke also. So istead of messing around and wasteing another $111.01 :x I just borrowed the one pice out of my brothers 84 or 86 F150 and it fits like a glove. The olny thing is the front of the driveshaft rubs the carrier berring mount. So if you go one pice I would suggest cutting that out,but make shure the one pice fits first :oops:.
:hj: Also I got a question why did some trucks use the blot on style yokes and cars don't?
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
