CNC Milled Aluminum Sun Visor Thingy
Ranchero50
Post by Ranchero50 »
As requested, It's coming, pics tomorrow.
Spent the day working on the contour G code for the mill. Spent the evening building and running the two first steps to mill the saw cuts ends to size. No idea on price, I whacked a 1" x 2" length of metal up to make these prototypes. Started with 28, down to 26 (setup piece and an oops).
More to come.
CAD of the profile and the cuts to get a 1" x 1.75" block there. It has a couple relief holes drilled before the cuts start:
Jamie
MAK
Location: Georgia, Blairsville - Florida, Flagler Beach
Re: CNC Milled Aulinum Sun Visor Thingy
Post by MAK »
Great! Can hardly wait to see the end result. I'm sure it will look great. :thup:
stangconv
Post by stangconv »
Well you know I am in on all your billet pieces.... PM when its ready!! Oh yeah my visor thingy is also connected to my mirror... Probalyl need a new mirror hey?
Oh yeah I got the light bezel and the ashtray door puller.... AWESOME!!! :thup:
fitzwell
Re: CNC Milled Aluminum Sun Visor Thingy
Post by fitzwell »
shoot me a pm when it's ready. What else do you have in the works?
Normally, i'm not a big billet fan, but that, along with the ashtray pull will look perfect in the 68.
pollock
Post by pollock »
Outstanding!
Joshpow
Post by Joshpow »
How bout the cd player plates? Glad to see progress on the visor mounts. Pics, PLEASE!!!
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
zakt
Post by zakt »
put me down for the visor piece as well, dont care for the plastic :D
Todd
1972 Ford F350 crewcab
Ranchero50
Doesn't look like much, but there are four of five steps done to the part in these pic.
Side milling the mounting recess. Had to go real slow to keep the tool from chattering in the cut.
Tomorrow at work I hope to get the sketches redrawn in BobCAD so I have a better record of the process.
Jamie
390F100
Post by 390F100 »
That looks sweet, man do you have some talent...
"There's no replacement for displacement"
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
Ranchero50
Still plugging away at the G code...
Here's a screen shot of tonights pain. All the pretty blue lines are roughing cuts that I needed to plot before getting to the final rough and finish cuts. .020" off each pass to keep it from chattering the tool to death. The program I'm using isn't real strong so I could only transfer a few segments at a time or the CAM program got confused, or at least I'll blame it on the CAM program. 12hrs of work, half hour nap, dinner and two hours of numbers and lines and I'm a bit burnt.
Jamie
ezernut9mm
Post by ezernut9mm »
you know i'm in line whenever your ready jamie.
Ranchero50
OK, 365 lines of code and several trips out to dry run them in the machine later I have a working program. Hope to build the fixture tomorrow and cut some aluminum.
Keep fingers crossed... :hmm:
Jamie
Ranchero50
OK, I have one prototype made. Took almost 26 minutes to mill out and the finish isn't that great and there was seom loading on the inside cut. Otherwise it turne dout pretty nice and follows the original part nicely.
Pics tomorrow, the cell phone died.
Jamie
Ranchero50
OK, pics are here, cell phone of course... so they suck.
The fixture to hole the part, 2" x 2" x 8". Has a step milled on the end as well as the reverse contour and two mounting screw holes drilled and tapped.
Three relief holes drilled.
Milling the contour, about half way done here. Note I'm using a 2" lead 3/8" end mill to cut the whole thing in one pass.
Finished part. looks good on this side.
The good...
The bad... The long end mill deflected while cutting so I need to overcome this before making parts. The divit is where the spindle loaded up in the cut because there wasn't anywhere to put the extracted metal.
I'm not sure what I'm going to do. I could just have it redo the finish cut a couple times and hope it cleans it up or redo the program to cut it from both sides, but then I'll have some mismatch where the cuts meet. I'm not real happy with this part, but I expected some deflection.
It's raining out today so maybe I'll go down and play with it some more.
Jamie :hmm:
stangconv
Post by stangconv »
looking good to me!!
I cant wait to get it!!! :D
