Instrument cluster
Instrument cluster
While cruising my local boneyard I came across a an F series 3/4 ton. Not sure of the year, guessing it's 69-72? Round headlights but with the plastic grill with the inserts. Any way I'm grabbing the springs but it's got a mint instrument cluster assembly. It's all one piece with the speedo in the center and the gas, temp etc at the outside corners. I dont think it will work in my daughters 67 but maybe I should grab it for a fellow enthusiast here?
Re: Instrument cluster
that sounds like a 70-72 truck. if the outer plastic is in mint condition it would be worth doing something with. the plastic front will come off of the backing and can be put into a 67 by removeing the front of the 67 guages.
Thanks
