rear axle shaft swap
- tybob81
I lost the paper I had written down what axle shafts from what 28 spline cars will work in our trucks to change the bolt pattern.
Re: rear axle shaft swap
From what I've been told, "...you need 2 driver's side axles and drums from a 1977-79 T-bird, 73-79 Cougar or Montego, 72-79 Torino, Ranchero, or LTD II. They are the right length and have 28 splines."
I haven't personally tried this, so I can't verify it's accuracy. But if you try this, please follow up to this thread with an update.
