Which Dizzy?
71PA_Highboy
Which Dizzy?
Post by 71PA_Highboy »
I need to tune up the OB, and I have a pertronix and a duraspark assy...
Which one should I use?
TIA,
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
averagef250
Re: Which Dizzy?
Post by averagef250 »
Pertronix is easier and cleaner to put in, duraspark is tougher.
71PA_Highboy
Re: Which Dizzy?
I think I will probably go pertronix... for only 1 reason...
I won't have to worry about pulling the dizzy and dropping the oil pump shaft into the pan...
Thanks Dustin.
Regards,
Eric
Got Ford?
1 Lincoln Mark VIII
heep70
Re: Which Dizzy?
Post by heep70 »
Spend the extra dough and get the pertronix II :thup:
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
averagef250
Re: Which Dizzy?
Definitely agree with Greg. The first pertronix fry if you look at them funny. I've had really bad luck with them.
fitzwell
Re: Which Dizzy?
Post by fitzwell »
averagef250 wrote:Definitely agree with Greg. The first pertronix fry if you look at them funny. I've had really bad luck with them.
Yeppers... and if you do fry the module, try finding one in Resume Speed Iowa.....ain't gonna happen.
I'd stick with the Duraspark unit.
71PA_Highboy
Re: Which Dizzy?
OK,
"I have a pertronix and a duraspark assy..."
I can't afford to BUY anything, so a Pertronix 2 isn't part of the equation.
Still going pertronix... still looking for input on why the risk of dropping the pump shaft makes the DuraSpark a better choice... and OB never gets more than 100 miles from home.. and most NAPA's around here carry pertronix...
eric
Got Ford?
1 Lincoln Mark VIII
averagef250
Re: Which Dizzy?
Sounds like you've had some bad luck with pump shafts in the past! Is the clip that holds the shaft in missing on your engine?
71PA_Highboy
Re: Which Dizzy?
Don't know it is is there or not, but I have dropped a couple in the past... and this engine looks close enough to original assy (though it isn't the original engine) that I am not really looking forward to the chance...
Will probably put a rebuilt 390 in the OB Next year...
TIA,
eric
Got Ford?
1 Lincoln Mark VIII
