idle issue
LUVMY69FORD250RANGER
idle issue
Post by LUVMY69FORD250RANGER »
seems to get stuck in drive, i have to constantly hit the gas pedal when i come to a stop to make the idle go to normal. otherwise it keeps driving without me hittle the acccelarot petal,. thanks for any replys.
THANKS
70shortwide
Re: idle issue
Post by 70shortwide »
check the choke linkage, it may be holding your throttle open a little.
while your in there check all of the linkage, spray it with a little carb cleaner, if it gets dirty it can be tempermental, and cause the symptoms your having
