88 302 Hipo bored 30 over?
- rjewkes
First is it worth anything if it runs, Second will it bolt into the 67-79 Small Block mounts? and will it bolt to the c4 in my truck.
![Image](http://www.fordification.com/galleries/albums/userpics/10175/sigpic~0.jpg)
fuelly.com
fuelly.com
- 69rangerman
Re: 88 302 Hipo bored 30 over?
I think it'll use the same mounts. It should also bolt up to the c4.
The biggest consideration is the harmonic balancer. I'm not sure when they changed the weight but I think the "newer" motors had a 50oz that matched the flywheel weight. Ours are usually 28. If it comes with the balancer and the flywheel you should be good, if it only comes with one then you'll have to buy the other to balance it correctly.
Flywheels are fairly inexpensive. Make sure you match the tooth count of the old one if you replace it.
As far as the motor itself goes .30 over is as much as is usually recommended for durability sake. If it runs you could do a quick vacuum guage check to see if the valve train works OK, and a compression check to see if the rings are sealing OK. Pull the valve covers and check for tar instead of oil, pull the pan and check for tar, copper colored bearings (bad), and grit, dirt, etc . If all that checks out and the price is right it's as good a gamble as you can make. Wouldn't hurt to pull the oil pump if you take the pan off and check the shaft to see if it's already on the way out.
Good luck!
![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
Good luck!
