but hopefully you can get some knowledge out of this.
first i bought a board that is called: 1/8" smooth panel board
then i cust it down to a reasonably size that i still knew was too big... measure twice cut once
so i got it cut to shape, very hard to do by yourself so try to get some help allthough i did it by myself. it wasnt fun though
and then after i got the shape (with about an extra in. on each side to allow for the reduction of size when its molded) i got my old iron that i use for waxing snowboards since it is adjustable hotness, has no holes on the bottom and was $1.00 at the thrift store.
and i got the squirt bottle we use to squirt the doggy
so...
here is the board cut to shape
here is why it is best to mold the corners
blue vinyl:
hanging from roof loosely
my weapon of choice, cuts through the board very nicely
iron and spray bottle for molding
i sprayed the board at the corner and got it soaked, then put weight on it to get it to bend. wait 10 min. and it should have a denent bend to it
flipped it over and this is what you get:
did the other side:
like i said, i never got to applying the vinyl (with spray adhensive that i bought) onto the board and installing it so i cant show a finished result.
let me know what you think of my legit craftsmanship
the board is pretty darn stiff so it can support some speakers
