nodular?
unclejtl
nodular?
Post by unclejtl »
ok, I was just in the project forum reading oldredford's project up date and had a question (didn't want to hijack).
what does nodular mean? It seems I have the same rearend. I just had new bearings pressed on and they were $80ea insted of $35ea. According to the driveline shop, he hardly ever sees these rearends. The axles are larger at the end the bearing goes.
According to my ID plate, I have a 3600#, 31 spline, 3:50 limited slip (ltraction loc, is what it's called in the owners manual) and 1250 lb springs, supposidly making it 5000lb GVW.
Is this good? Is it common? what is nodular? :?
Thanks.
Jason
71PA_Highboy
re: nodular?
Post by 71PA_Highboy »
Nodular is a type of Iron. It has a higher alloy count (more graphite) that allows it to be stronger and more ductile.
http://en.wikipedia.org/wiki/Ductile_iron
:2cents:
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
unclejtl
Post by unclejtl »
interesting, thanks.
what are the others made of?
Jason
averagef250
Post by averagef250 »
Nodular is better. Nodular is also sometimes referred to as cast steel because it shares steel properties. The nodular 9 inches have a large "N" cast into the center chunk.
You have a very rare 31 spline bumpside 9 inch by the sound of it. Most are 28 spline. And yes, the wheel bearings are darn near impossible to find anymore and they're huge.
unclejtl
Post by unclejtl »
Any Idea as to why ford did this? If the outer housing is the same size and the axle is larger in that area, it appears that the bearing would be smaller between the I.D. and the O.D.. Did ford have a problem with axles breaking to make it this way?
Jason
averagef250
The outer housing is not the same size. The housing itself has larger tubes and tube ends than the standard 9 inch.
BobbyFord
Post by BobbyFord »
I have an equally rare diff in my truck. 31 spline, 3L50 but a 9 3/8" gear set. I too had to spend the extra $$ for the big bearings.
unclejtl
Post by unclejtl »
averagef250,
Thanks, I have not seen a standard. The shop that did the bearings told me it was. :oops:
BobbyFord,
I believe we have the same. I was under the impression tha everyone called a 9 3/4" a 9" :oops: . Mine is actually a 9 3/4" 3L50 WFF-B (whatever that is)
Is it this large axle that makes it a 3600# instead of a 3300#?
Jason
BobbyFord
Post by BobbyFord »
unclejtl wrote:averagef250,
BobbyFord,
Yes, that's the large axle.
You can tell a 9 3/8" diff by the way the top rib on the pumpkin curves down on the driver's side...like this-
cdherman
Post by cdherman »
So are there any clues as to what sort of truck would have these 9 3/4" rear ends? They would be a bolt up for trucks up to 72 as I understand it. Meaning, the whole rear axel would swap over.
I should be looking for them, as my next project (in my dreams) is a 67-69 with a VERY large V8 that will twist off 28 spline axels like I can twist off a bottle cap..... So goes the dream.
But in any case, it would be a waste to have one of those heavy rears go to a crusher.....
BobbyFord
Post by BobbyFord »
cdherman wrote:So are there any clues as to what sort of truck would have these 9 3/4" rear ends? They would be a bolt up for trucks up to 72 as I understand it. Meaning, the whole rear axel would swap over.
They're actually 9 3/8"
I think they must have been special ordered tow package or something. I don't understand why Ford would just put one in there. Mine came stock that way. I've seen a couple of others.
Just keep your eyes peeled at the boneyards for that curved upper rib on the pumpkin. Incidentally, the housings are different in that they are notched from the factory where the pumpkin bolts in to accomodate the larger ring gear. A non-9 3/8" housing can accept the 9 3/8" pumpkin but the housing has to be notched first.
cdherman
Post by cdherman »
averagef250 wrote:The outer housing is not the same size. The housing itself has larger tubes and tube ends than the standard 9 inch.
But this poster seems to indicate that the whole rear end is heavier....
But I assume the shock mounts and spring perches would still be in the correct locations, right?
unclejtl
re: nodular?
Post by unclejtl »
Thanks for the clarification again BobbyFord :oops: I have the one like in your photo, but it's not as purdy :D
By the way, you seem like such a nice guy for such an evil photo :eek: :lol:
Jason
averagef250
The housing is different from the outside. It's hard to describe, but the weld seam where the tubes meet the center housing is further outboard than the standard 9". The shock mounts and spring perches are identicle to a standard truck.
The only bumpside I've ever seen with the 31 spline 9 inch was my 1970 F-100. It was an ex-weyerhouser fleet truck and was a base model with manual steering, manual brakes, a 360 and T-18 4 speed. It was the highest GVW F-100 they offered though I forget what the rating was. The rear end was also 3.50 gears and had a trac-loc limited slip.
OldRedFord
Re: nodular?
Post by OldRedFord »
Hate to drag this thread back up, but any one know what the #s are on the wheel bearings?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
