302 swap
- td
re: 302 swap
I know for sure the I-6 frame mounts won't work. you'll need to find some v-8 frame mounts. are you swaping trannies as well?
re: 302 swap
yes i will be swaping trannys too. mine is toast
re: 302 swap
http://www.fordification.com/enginestands.htm
It'll physically work, but using FE/I6 stands for a 302 will cause the engine to sit app. 1" too high, altering the driveshaft angle. The best scenario would be to find the proper small-block stands.
However, you could also just shim up the transmission crossmember a similar amount to match the engine stands. Not the ideal solution, but not totally 'ghetto'.
- AK F100
Wow, good info. Going from memory only, I think my truck has I6 stands and the truck had a 289/302 in it when I bought it.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
- averagef250
re: 302 swap
so what do you guys think would be the best v8 for a swb bump. i want power but i dont want to spend alot for it
- sideoilerfe
averagef250 wrote:You could also swap a 300 in place of the 240 and have more truck power than a 302 could ever dream of.
A 300 is an excellent motor. Visit www.fordsix.com for performance advice.
To be honest, a 300 is best for low end torque. They'll not only pull anything but they'll outlast any V8. They're not high revin' horsepower engines but you can build them to be quite impressive.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- j41385
re: 302 swap
Add another vote for the 300, and see my signature.
1968 F100 Took the running 390 out, and installed a Built 300 with AOD.
Engine Video... http://youtube.com/watch?v=2xgYd2u79NU
re: 302 swap
i found a complete 1981 302 with around 100,000 miles for $150 supposed to run good. but i heard that the 80's engines are smoged down an have less power than 70's engines is this true
- GT-Racer
if going witha small block why not get a 351w? it is essentially the same swap as 302 and you get a bunch more torque. I have a mild 72 351w making 400 hp. Just a cam, headers, aluminum intake and 4bbl.
80's are definitely down on power from older models.
I may have a set of small block perches if needed. pm me.
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
I'd agree with going with the 351W if keeping it small. This 400hp, I'd really like to see with just a cam, hedders, and 4V intake. I built a 351C- 4V(closed chamber 4V heads) that had about $3200 worth of parts in it, and it was 330hp at the wheels. I just dont see 400hp happening with W heads, unless they're aftermarket & high flow....I'm not trying to be pi$$y about it though.GT-Racer wrote:if going witha small block why not get a 351w? it is essentially the same swap as 302 and you get a bunch more torque. I have a mild 72 351w making 400 hp. Just a cam, headers, aluminum intake and 4bbl.
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
08 VW R32
- basketcase0302
re: 302 swap
mattr67,
http://www.worldcastings.com/prods_page ... r_alum.htm
Hopefully I'll own one of these before I die...
Build it to a 347 stroker and you got one bad-to-the-bone small block.
Basketcase
I don't think any of Ford's I-6's can touch this 302:You could also swap a 300 in place of the 240 and have more truck power than a 302 could ever dream of.
Basketcase
- averagef250
Actually, I'm pretty sure a bone stock 1V 300 would walk all over that 302 with a 5000 pound trailer in tow.
For a TRUCK you need a TRUCK engine. A 302 may be a great engine, but I can gaurantee the engineers who made it with it's dinky little 3" stroke and light rotating mass had no intention of putting it in a fullsize truck.
And to the mild 351W making 400HP is that with a 200 shot of nitrous? I have respect for the 351W, it does fairly well for it's size. I've done a lot of wheeling with a brute low end torque one in an early bronco, but even being able to pick the front tires off the ground with a hard 3-2 downshift at 25 MPH I seriously doubt it's making more than 200HP and 300TQ.
- basketcase0302
re: 302 swap
Forgot how to spell relentless...
There are literally thousands of these documented, want a couple more?
http://uk.youtube.com/watch?v=3zhYTFWAI ... re=related
Basketcase
Basketcase
