352 Rebuild Kits - Need Advice
tcox67
Post by tcox67 »
Hello All:
My son and I are working on a 1967 F250 Camper Special with a 352 and the engine has a major hole in the right side. I was able to get a complete 1964 352 locally for $90 and we took it apart to do a total rebuild. Right now it is down at the machine shop getting hot tanked and inspected. The machinist said the crank is fine but the cylinders need to be bored .030 over and that all of the valves need to be replaced. My question is where is a good place to buy the rebuild kit and valves?
Thanks in advance.
flatblack
re: 352 Rebuild Kits - Need Advice
Post by flatblack »
the best place i have gotten rebuild kits from is actually on ebay. i did 2 302 rebuilds and a couple of 351M and W rebuilds with these kits. i dont deal over ebay tho i just called him up and ordered call brian at promar engines
CONTACT US
If you have any questions please feel free to call toll free @ 1-800-422-6022. Ask for Brian or email me brianb@promarengine.com
im sure if he doesnt have the 352 rebuild in stock im sure he can put one together for you.
heres one of his rebuild kits
http://cgi.ebay.ca/86-91-Ford-302-Engin ... m153.l1262
Nitrous is like a hot girl with std's... you know you want to hit it but your afraid of the consequences
sideoilerfe
Post by sideoilerfe »
Remember the pre '65 blocks don't have the motor mount holes needed for our trucks. There's a write up here somewhere about it but if i remember correctly, the '65 and later FE's have 4 holes where the '58- '64 only had 2. You need the later block to bolt it into your truck without fabricating an adapter.
Someone like Keith or Hawkrod could be more specific on this than I can.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
tcox67
Post by tcox67 »
Thanks for the information. I just called the machine shop and he said the block has 4 bolt holes on each side for the motor mounts. He also gave me the casting off of the block and it is C5AE-A. I looked it up in the chart but that doesn't appear to be a 352. The crank has a C4AE which points to a '64 352, which is what the engine came out of. I am not sure what to do with this one.
sideoilerfe
That sounds like a '65 block. The machine shop can measure the bore and determine what it is.
