Putting in new clutch kit, should i have fly wheel resurfaced shows little wear. And is a flywheel like a brake rotor, is there a possililty it can't be resurfaced if it has been once before
Also this is off of a 302. Are there marks that i need to line up with when it goes back on
putting in new clutch
- peanutman
http://s533.photobucket.com/albums/ee33 ... e_Johnson/
1970 302,ps, ac, 3 speed o.d.
- peanutman
Thanks kap for the reply hopefully someone else will know about flywheel alignment on a 302.
- 69timemachine
re: putting in new clutch
If I remember correctly, my 302 I used to have had the flywheel bolts slightly staggered to where the flywheel would only go on the crankshaft in one position.
Jason
"Where there's a wheel, there's a way!"
'69 F100 SWB in Lunar Green with built 351C & TKO-600 5-speed, 4.56 gears, and Eaton TrueTrac Posi.
Future plans: Maybe one day, fresh paint, though I've been told by some, "Don't touch it! It's done!"
'06 Mustang GT 5-speed
Sold: '77 F100, '72 Gran Torino, '76 El Camino with 454 & TH400
- unclejtl
69Timemachine is correct, I just did mine.If I remember correctly, my 302 I used to have had the flywheel bolts slightly staggered to where the flywheel would only go on the crankshaft in one position.
Jason
