F500-F600 transmissions?
What transmissions came in these beasts? I heard that some of them have 9 speeds? Its hard for me to believe though just thought I would ask.
Dan
'69 F350 Crew Cab
'69 F350 Crew Cab
- SteveC
re: F500-F600 transmissions?
I believe it was a regular 4 speed but i also remember there being a 2 speed rear axle ...basically giving you 8 forward gears and two reverse.
Dads 72 ford N600 is setup this way.... though that thing has the screwiest shift pattern.
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
Depended on drivetrain options when purchased. some had 4 spd and some had 5 spd. Some had 2 spd Electric, Air, or Vacuum operated rear axle. I don't remember any 9 spd available in this small a truck.
The goofy shift pattern may be the result of an OD tranny. The two top gears had reversed positions on some trannys with OD.
Fred
Fred
- kaptnkaos
Hey LOWERED '69
Many of the F / B 500-600's had Clark 5 speeds w/a 2 speed rear end.
That's what's in my '68 B-500 bus Olde Skool.
Also, like has already been mentioned, they had NP435 4 speeds as well.
I have a 361 FT, that came out of a U-Haul F-600, that came with an NP435.
It is a little different than the light truck version in that the tail piece has a drum brake mounted on it and an e-brake lever that comes up thru the tunnel cover.
KaptnKA S
KaptnKA S
- averagef250
The older medium duty fords used the NP435 as the base tranny. If it has a screwy shift pattern as a 4 speed it's an NP540. The 540 was made in both 4 and 5 speed versions. The 4 speed is a 5 speed minus second gear with 2nd and 3rd gears from a 435 installed. Screwy shift pattern and 5 speed could be either a clark or NP540.
Many of them had allison 545's as well.
- kaptnkaos
Hey averagef250
That's good stuff to know...
Thanks
KaptnKA S
Thanks
KaptnKA S
- fomocoguy
Ok, so the real question is if I was to come across a 5 speed F600 in the junkyard, would the trans bolt into my highboy???averagef250 wrote:The older medium duty fords used the NP435 as the base tranny. If it has a screwy shift pattern as a 4 speed it's an NP540. The 540 was made in both 4 and 5 speed versions. The 4 speed is a 5 speed minus second gear with 2nd and 3rd gears from a 435 installed. Screwy shift pattern and 5 speed could be either a clark or NP540.
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- 19674x4
that and clark 5 speeds with 2 speed rears. like allan said
My Photo Album
- averagef250
