want auto trans
want auto trans
have 75 f100 with 3 speed on colum.would like to put auto c6 moter is from 91 lincon also has split drive shaft
- craftsman
Find a donor truck, 78-79 get steering column, brake peddle assembly, all linkages, driveshaft,(or modify your driveshaft) flexplate,(be sure to get 50 oz flex plate if you have a 91 engine) trans cooler lines, radiator with trans cooler built in.
Be sure to get c6 for the correct engine family you have, i assume you have a 302, so if you want a c6 for it, it will need to be from 78 or later truck. You may need to relocte the cross member for the trans, just drill new holes. Your crossmember will work for the auto trans. If i left something out someone will correct me.
- F100builder
re: want auto trans
Hard to know which motor you have but I'm guessing a 5.0 (302) if it's from a '91 Lincoln. If the motor is a small block, then I would say go with a C4 over a C6 as the C6 robs a lot of horsepower. If you're set on the C6, you'll need one to fit your block as there are 3 different bell housing bolt patterns (small block, FE big block, and 429/460). If it was me, I'd think about an AOD (still assuming it's a small block) if you like the idea of an overdrive for highway cruising. Be sure to look for an AOD and not the AODE (E for electronic overdrive). The AOD ended in early '92 I believe.
Patrick
