safe FE revs...
- bigjake34452
safe FE revs...
hey guys, i dont know anything about the FE engines, i will be getting a 73 f100 with either a 360 or 390, i was wondering, what do each of these engines rev out to safely?
- 19674x4
dont go much 5 grand. they were made to produce power at low rpm's and you will notice the torque curve drop at or around 5k.
My Photo Album
- bigjake34452
re: safe FE revs...
thanks man, o and one more thing i forgot to mention, is there a way to tell the difference between the 2 by the outside just looking at it?
- j41385
re: safe FE revs...
Nope. You have to measure the stroke.
1968 F100 Took the running 390 out, and installed a Built 300 with AOD.
Engine Video... http://youtube.com/watch?v=2xgYd2u79NU
- averagef250
- 19674x4
i get my 352 to 5k but thats about it. 2nd gear pinned. after that it loses power and powerband drops
My Photo Album
- Redcap
- Ronnie1972
re: safe FE revs...
Hey Jake,
One of the GREAT "Did you know" tips describes using a dowel rod with the engine at TDC. Stick a dowel rod in the first cylinder, measure to some point on the outside (a reference point like lip of valve cover or something). Now take it out and stick it in the 4th. Measure to some point (same point) on the outside. Measure the distance between the two and voila, you've verified if it's a 360 or 390. Exact stroke is somewhere in here. Worked great for me.
1972 F100 Sport Custom - 390, C6, 3300# Ford 4.11 rear.
re: safe FE revs...
well here's a question, why is that my '72 crew diffs are geard like a tractor with a granny low 1st aswell? These FE's make low end power so why not taller gears? I can't do over 55mph without it sounding like it's trying to escape from under the hood. Then low range 1st is too slow for rock crawling even
BTW, it's stock except for the engine
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
'72 crew 4x4
'07 KTM 450 xcw
- ToughOldFord
re: safe FE revs...
Granny low is for serious loads, don't use it if you're not hauling anything.
Don't understand your gear problem though, even when I had my 4.10s I cruised at 75mph with no issue. Maybe you just have a lot of engine noise?
Re: re: safe FE revs...
That could be, Id like to put a tach on it. But it sure seem to rev high and lose power around 50mph.ToughOldFord wrote:Granny low is for serious loads, don't use it if you're not hauling anything.
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
'72 crew 4x4
'07 KTM 450 xcw
- RedneckTexan
That's what makes the bumpsides so strong! Tractor gears in the diffs (4.10-1 for me) and the 6.68-1 for first gear in the tranny makes these trucks the kings of haulin! I can't tell you how many thousands of pounds I've loaded into my 68 F-350, but I can tell you she has NEVER strained, no matter how big the load!James72 wrote:well here's a question, why is that my '72 crew diffs are geard like a tractor with a granny low 1st aswell? These FE's make low end power so why not taller gears? I can't do over 55mph without it sounding like it's trying to escape from under the hood. Then low range 1st is too slow for rock crawling even
- Chaseman
re: safe FE revs...
Yeah I have a pretty steep gravel driveway and to avoid messing up the
gravel I stop at the bottom , put it in low and just idle up. Sometimes I forget
the mail so I just get out while it's going up and run to the mail box then get
back to the truck before it gets to the top. Or if it's flat and me and my friend
are bucking hay I stick in low and get out and let the truck drive itself while
we buck hay
Btw it has the NP435 with 4:11 gears
we buck hay
- RedneckTexan
I've done that a time or two BTW, my truck has the same set-up.Chaseman wrote:Yeah I have a pretty steep gravel driveway and to avoid messing up the
we buck hay
- 19674x4
that makes three of us.
My Photo Album
