I looked at a dana 44 from a '78 F250 for my '72, I've heard it's a direct bolt in but the steering arm looks longer and in a different position. He will give me the steering box and pump too, wich would be a nice upgrade. Do I need a different steering collum shaft (shorter) to use the '78 setup? Or should I (can I) just bolt in the '78 axle and use my old PS setup? He had a '72 with an entire set up from a '78 in it, but it has 10" of lift and he didn't put it in so he had no info, it also looks like the pitman arm rubs the bottom of the frame.
Thanks
James
'78 44 in a '72
'78 44 in a '72
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
'72 crew 4x4
'07 KTM 450 xcw
re: '78 44 in a '72
As shown, my box is on the inside of the frame with the shaft through the frame, the one he has the shaft sticks straight down with the pitman arm sweeping below the frame parallel with the ground.
This is the steering arm on mine, the other one looks more like a boomerang.
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
'72 crew 4x4
'07 KTM 450 xcw
