T-case question?
04stangman
T-case question?
Post by 04stangman »
Hey guys, I have a 1969 F250 with a NP 205 transfer case. Me question is on the top rear of the tcase there looks like there used to be something connected to two nipples? There is one pretty much on the top rear, it looks like its a fitting for a rubber hose or something and the tube is sealed shut with something. And the other on it on the top, driver side rear, it looks like it might be a cable fitting? but there is nothing connects to either one? Any ideas on what if anything should be connected to me transfer case? Thanks!
convincor
re: T-case question?
Post by convincor »
I beleive on the 205 one would be for a vent hose, the other would be where a 4WD indicator switch would go.
But shouldn't that be a Dana 24 in that truck?
But then again, the automatic shouldn't be there either :wink:
"Still Plays With Trucks"
Redcap
Post by Redcap »
You sure it's a 205? If it's the stock one, in 69 I'm pretty sure it's a Dana 24.
04stangman
Re: re: T-case question?
Redcap wrote:You sure it's a 205? If it's the stock one, in 69 I'm pretty sure it's a Dana 24.
I thought based off the pictures I have seen it looks like a NP 205?
convincor
Post by convincor »
Dana 24 should have the ID tag on the driverside lower case.
No pic.
The 205 would be front bottom.
04stangman
convincor wrote:Dana 24 should have the ID tag on the driverside lower case.
No pic.
This pic looks like mine from that angle.
