rear wheel leaking
mike73
rear wheel leaking
Post by mike73 »
There is some type of oil leaking from my passenger rear wheel. It is almost like gear oil. Have not taken it apart yet but whatever it is it seems to be comeing from the hub and running down my tire on the inside and there are 2 big spots in my driveway. Any ideas what this could be? FInally got the tranny to stop leaking and now I have a new leak. :doh:
I love my old truck.
iamthewreckingcrew
re: rear wheel leaking
Post by iamthewreckingcrew »
Probably an axle seal. Possibly brake cylinder leaking.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
MadMaxetc
Post by MadMaxetc »
If it is brakes it will have very little odder.
If it is Axle fluid it will stink like all hell.
Dan
FORD Girl
Photobucket Pictures
ford4x4fun
Post by ford4x4fun »
MadMaxetc wrote:If it is brakes it will have very little odder.
didn't know that.... Good Stuff :thup:
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
I'm just picturing the neighbors walking by while he's out in the driveway with his nose to the ground. :loco: :lol:
iamthewreckingcrew
Yeah, used gear oil smells terrible.
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
also check the axle breather for plugs. if its plugged it can force gear oil out of the axle seals.
MadMaxetc
Post by MadMaxetc »
fordman wrote:also check the axel breather for plugs. if its plugged it can force gear oil out of the axel seals.
:yt: It is the "bolt" that holds the splitter bock for the brakes on the housing.
Dan
FORD Girl
mike73
Post by mike73 »
Yep its axle fluid but the seal on the inside seems OK. I think its the bearings, the seal around them seems to be a bit warped. Cant get it off though.
mike73
Post by mike73 »
Finally got the bearing off. It is what is actually warped. Had to machine the darn thing off. What a pain.
F100builder
Post by F100builder »
A warped bearing? I haven't heard of that.
You'll need to press or have someone press the new bearing on and I'd grab a $5 seal and replace it too while you're at it. Does the axle look OK where the seal rides or is a groove present? If there is a groove, a new seal probably won't seal and you may need to get the axle built back up and then machined back down to spec. I've also seen rear end housings that are warped from people welding on them. It's nothing that you can really see with the naked eye but they go through seals in a hurry.
Patrick
mike73
Post by mike73 »
Yeah the inside of the bearing was dry as a bone. The meatal piece that seperates each individual bearing was broken. I also grabbed a seal but I cant seem to get the old one out. Will work on it more this weekend. Had to heat up the other bearing and press it out. Gonna take the new one and have it pressed on.
mike73
Post by mike73 »
When I pulled the hub off a piece of the bearing fell right out. It was the piece that wepperates the individual ball bearings.
i had to chamge a bearing once or twice. i had to press them on and off of the axle. the seal has always been pried out witha screwdriver or a real seal puller tool. it looks like a small mountianiering pick kind of. it is hooked on both sides.
