Lockers?
green68250
Lockers?
Post by green68250 »
What are you guys running for lockers/posi units in you 9"s? I want to put one in my rear end I just don't know whats out there and whats good. How hard was is to install? What was invloved? Any tricks?
Thanks,
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
convincor
re: Lockers?
Post by convincor »
you'll need a press, dial indicator with magnetic base, inch pound and foot pound torque wrenchs.
I would be fine with a stock 4 pinion traction lock as my truck isn't going to raced, but I got a good deal on a Currie traction lock so I grabed it.
They can be bought new for $400 in 28 or 31 spline. The Ford units run about the same price but the Currie is much stronger. So if you where to go new, I'd say go Currie.
Shop tec here- http://www.broncohq.com/dmp-6677CH.html
"Still Plays With Trucks"
green68250
re: Lockers?
Cool, thanks. Are you happy with the Currie? I saw those for sale on Jegs. I was also looking at the Eaton Posi LSD unit but I haven't found an online place that sells them to get a price.
Corbin
convincor
re: Lockers?
Post by convincor »
It's still on the shelf in the garage, but looks wise it's real nice. :D All billet machined surfaces, not cast like the Ford units. The clutches to rebuild are about the same as the Fords.
Did a quick look for that Eaton and they don't seem to list it for the 9".
xxxtina63
re: Lockers?
Post by xxxtina63 »
On a side note, I don't know what type of weather you'll be driving in, but some people don't care for the way a locker behaves on icy roads. Makes the rear slide a little on corners if you're not used to it. Personally, I like them and can deal with it. I like the extra traction. :2cents:
