What kind of rearend do I have?
Georgia71
Post by Georgia71 »
I know that this is a ford rearend but! I have been driving everywhere for these parts. The vin code plate on the door has the 08 code. Which translates to 3.50-3300# Ford. I know my Dad changed this thing out several times. Experimenting with different gear ratios. The one I currently have is a 3.25 gear. I guess that explains why I was getting 13 mpg. I'm currently having a hard time getting the axle seals for this thing. The last place I went to was NAPA and I think they gave me the wrong seals. You set the old seal and new seal flat on the table and the new one is thinner. The old seal stands up higher. Does this make a difference? Or does the inside and outside diameter only matter? I bet I've used up 5 gallons of gas looking for these things.Maybe I should just get from lmc. Who usually has these seals?
Larry :?
SteveC
re: What kind of rearend do I have?
Post by SteveC »
are they rubber seals???? is so they may have swelled i know dad and i argued back and forth over something like this before i proved it fit and worked perfectlly
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
heep70
Post by heep70 »
Alot of new seals are made that way now (thinner) :o . If you can't get ahold of the same thinkness seal. The thinner seals work just fine. Just make sure the ID and OD of the seal is that same as the old seal.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
RedneckTexan
Post by RedneckTexan »
If your asking what rear-end you have, it's a Ford 9 inch. :2cents:
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
:lol: what size pants do you wear? :lol: just teasing you.
Georgia71
Post by Georgia71 »
Thanks for all the replies folks. I went to a different napa today and he had the same looking seals as the other. But the part number was different. The one I got before was for the 3600 lb. axle. The ones from today are for the 3300 lb axle. They are thinner or should I say not as deep as the other ones. I'm going with these anyway being it doesn't matter and they are the same id and od.
Larry
FLATBEDFORD
Post by FLATBEDFORD »
Turn around, let us see.
My Photo Gallery
RedneckTexan
:lolprev: :evil:
John
Georgia71
Post by Georgia71 »
:oops:
