What color should the bellhousing be?
SportCustom
Post by SportCustom »
Should it match the block or the trans?
My trans has a cast grey color (BW-T85) but the motor is the ford blue. How was this painted from the factory?
Thanks,
Todd
1970 F-100 Sport Custom
390 FE
CV/8.8 Swap
i bet it was no color at all. i would paint it brite silver. so you can see it better when under the truck working on it or putting it back on.
SportCustom
I just stripped an original truck and the only paint that I could tell was just overspray from the back of the motor.I will make it match the trans I guess, and it will be cast looking so may appear original.
390 FE
CV/8.8 Swap
averagef250
Post by averagef250 »
I don't think the transmissions/bellhousings were painted at all. I know the transmissions were bare iron, the apparently original virgin trucks I've pulled down have shown no signs of paint on the bellhousings, just oil and dirt.
SteveC
re: What color should the bellhousing be?
Post by SteveC »
i my self (having NO color cordination at ALL)think it would cool satin or flat black but htats just me
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
yes silver is bad for holding up. the only reason i suggested that was because it is easier to see when you are putting it back in.
SportCustom
I am using the cast color engine paint. That way it looks original but is painted.
390 FE
CV/8.8 Swap
