whats involved in a transmission service,
LUVMY69FORD250RANGER
Post by LUVMY69FORD250RANGER »
im driving around with old oil, still looks red but some black. plus when i accelrate into 1st gear , its a automatic, i get kind of a little bump, does it need to be adjusted? and it is changing the oil really hard/??
THANKS
changing the fluid isnt that hard. you want to drain the torque converter and then aslo remove the pan and drain it at the same time. there is also a filter inside the pan that needs to be changed at the same time.
the little bump you feel when it shifts could be from low fluid levels or wear to the transmission.
THANK BUT
fordman wrote:changing the fluid isnt that hard. you want to drain the torque converter and then aslo remove the pan and drain it at the same time. there is also a filter inside the pan that needs to be changed at the same time.
is there any adjustments they make?? they got a 69.99 special at a tranny store
THANKS
BRUTUS_T_HOG
Post by BRUTUS_T_HOG »
they adjust bands if they're adjustable
ASE Certified Technician
basketcase0302
re: whats involved in a transmission service,
Post by basketcase0302 »
luvmy,
Like Brutus said the bands.
And...
If it's a C-4, a lot of our members here are too young to know this.
There was a recall on the C-4's back in the 70's.
They were "falling" into reverse.
I had gotten one of the notices because my Maverick had the C-4.
The linkage adjustment should also be checked.
Basketcase
